Network and Planar
All  1-4  5-8
6077.5 In reply to 6077.4
Hi Andrei,
> May be it is reason to merge - Network, Planar and nSided in one command?
It tends to be difficult to merge commands that do different things with the same inputs - you can have a planar set of edges for example but running Planar on it generates a trimmed plane, while NSided generates a non-planar tangent covering.
I have thought some though about possibly having a general "Fill" command that might be some combination of things.
6077.6 In reply to 6077.5
I thought this way for example, you run this merged command and it looks: If it can made network it made if not it tried to make planar if impossible than NsiDeded. Something like this. These command can be ran only in certain circumstance. They can not be run all at the same time. Becouse for example planar have to have planar curves, Nsided must have surfaces, Network non planar curves not less then 3 if I'm right)
Just some kind of sorting out the commands.
6077.7 In reply to 6077.6
Just thought a bit... nSided and Network can be run at the same conditions only when edges are selected. So may be it is not simple work to merge them together.
EDITED: 1 Aug 2013 by ANDREI SAMARDAC
6077.8 In reply to 6077.6
Hi Andrei,
Network can work on planar curves, and it could be possible that you might want to create a planar network in order to use the resulting surface structure in Flow.
For Planar / NSided, this is the kind of situation that can apply to both:
Show messages: All  1-4  5-8
