Death of SUB-D Artist)! Closed
 1-13  14-33  34-53  54-73  …  114-119
Alas Groboto/Modo is for the moment stopped!
http://www.groboto.com/forums/showthread.php?940-GroBoto-Lives-On
  More Options
6076.15 In reply to 6076.14
I don't understand. He lays out a timetable right there in that post that says:
"The GroBoto-derived modo plugin will be released later this year."
How does that translate to it being stopped?
Plus, Darrel is in the Luxology forums every couple of days showing off teaser images and videos...
  More Options
6076.16
Indeed groboto dev seems to be slow down, but there is a modo plugin coming.
  More Options
<< How does that translate to it being stopped?
Adjourned if you prefer - so re-launch as soon as possible!
EDITED: 31 Jul 2013 by PILOU
  More Options
6076.18
Hi Andrei:
I think all benefits and pleasure you have using Moi not derive totally from Nurbs environment
You can find same Nurbs tools in lot of applications..so is not only a challenge Nurbs Vs. Sub-D
It's MOI that bring all benefits and speed-up your workflow
Watching your video which are things that allow to build that model so easy and quick ? Snap and selection
Those two things are best of the 3Dworld !!!!Which other software gives you same easy to use to select,move,jump between wiews or EASILY catch a snap point ?
NO-ONE !
These features are the base of workflow...tools or technique come last
I'm testing Autodesk Fusion 360 with T-Splines
While i'm workin on, i need a snap:where is the palette?
Nothing...i do a search on their site:this is what is turned out :) :) :)
 http://forums.autodesk.com/t5/Request-a-Feature-Fusion-360/Object-snap-is-really-needed/idi-p/3818119
EDITED: 31 Jul 2013 by M-DYNAMICS
  More Options
6076.19 In reply to 6076.18
M-dynamics, totally agree with you)
I do not wanted to start this thread to contrast Sub-D vs Nurbs, just wanted to show what can kill Sub-D modeler :)) and make it in funny way!
But it looks like there is some foggy soft that is not released yet, that can reproduce boolean part of MOI :)
About Autodesk, Is it you started those thread about snap? Why? Let user of Fusion to suffer a bit :))) Do not have snap looks like do not have air...... I see a lot of soft of autodesk is not perfect, but has well known brand.. Personally there is no any soft of Autodesk that I like...
Just wanted to ask if GroBoto has some kind of snap functionality?
EDITED: 31 Jul 2013 by ANDREI SAMARDAC
  More Options
6076.20 In reply to 6076.19
"But it looks like there is some foggy soft that is not released yet, that can reproduce boolean part of MOI :)"
You think that video is merely reproducing what MoI booleans do? I give up.
It must be a language barrier problem and I can accept that. This thread has no right to be as annoying as it is! :)
  More Options
6076.21 In reply to 6076.20
Booleans is booleans no matter is it nurbs or sub-d or MOI or Max or Rhino or GroBoto... or I'm wrong?
I can see only one difference in Groboto they automatically updates and you can keep parts.
All that stuff can be reproduced in moi not so graphically but it is not a big deal)
This is it :) What so confused you?
  More Options
6076.22 In reply to 6076.21
Dynamic booleans are a BIG DEAL. A really big deal. HUGE in fact. Just ... trust me, I guess! Every artist I work with or know who sees that is blown away and can't WAIT to try it out.
"All that stuff can be reproduced in moi not so graphically but it is not a big deal"
And I can reproduce your example at the start of this thread in a subd modeler - that doesn't mean that what you're showing in your video isn't better. It is! And that's the same as these dynamic booleans compared to static booleans. These are WAY better.
  More Options
About Groboto
If i well remember it's snap like "middle" or "extremities" !
UI is not very "friendly" ;)
Groboto is also more for "automatic bots" figure result!
In this video all repetitive geometries is Groboto!
  More Options
6076.24 In reply to 6076.22
Can not see any big deal in it, really)) Just for concepting, may be some new ways to find new shapes.
Do no not agree with you, I can not imagine that you will model this figure I showed in first post in Sub-D in 2 minutes...
But any figure that you show me that was made in Groboto I reproduce in "seconds" in MOI.. may be except those abstract stuff that Pilou showed.
  More Options
6076.25 In reply to 6076.24
"Can not see any big deal in it, really)) Just for concepting, may be some new ways to find new shapes."
OK ... awesome. Well, I'll be on my way then.
  More Options
6076.26 In reply to 6076.24
@Andrei:About Autodesk, Is it you started those thread about snap? Why? Let user of Fusion to suffer a bit :)))
I didn't start that thread,but a user that also use MOI..take a look at the image he attached: Moi Snap Palette as reference for Autodesk !!!! :) :)
...more:they said can import 3dm files...i tried surfaces,solids but fail all times,so i exported from Moi in Sat,and it works
...more:you can't convert the whole surface in T-Spline surface then edit....must delete a single face, make a patch and convert that patch in T-Spline surface.... :)
I think dynamics booleans are great stuff considering how is difficult make it in Sub-D
if i remember correctly,Groboto was also a C4D plug-in,that gave a ultra-clean mesh after booleans
Modo+Dynamic booleans+CAD loader plug-in...you won't need T-Splines for sure!! All this for 2000€/$ more or less...
same price of Rhino+T-Splines...without one of the best UI of 3DWorld(just second to MOI :) ),Recoil soft-rigid bodies,animation,a good renderer and more....
Yes..if i could spend some money Modo should be the choice.
M
  More Options
6076.27 In reply to 6076.26
M-dynamics,
looks like very strange stuff.. that Fusion..
About soft, for example I can not work not in Rhino nor in Modo))) After MOI just can't ))))
Portfolio: www.samardac.tumblr.com
  More Options
6076.28 In reply to 6076.27
Groboto is not "New"...
it does those booleans and maintains an "all quad" topology mesh.
It's mesher is unique and powerful.
It is a "tool" with a unique capability. The "bot" is 1.
  More Options
6076.29 In reply to 6076.27
That's only one problem about Moi:is addictive !! ..so:be careful.. :)
but you're using now also 3DCoat and C4D..hope you'll use them also for modeling
..if not..force yourself avoiding to fall in addiction ;) :)
I started a Rhino course few months ago
i came from Autocad and Moi,so,no problem at all
Teacher gave us to model a simple abat-jour (bed lamp)
Rhino 4 Snap paralyzed me!! :) :)
I copied the exercise on my pen-drive,went back home i did it in MOI ;) :)
Next lesson i showed to the classroom my cool model
but i was honest..at the end i said the truth(i did that course just to improve my skills)
i'm addicted :)
Thanks Burr,you confirm what i supposed
  More Options
6076.30 In reply to 6076.29
M-dynamics nice story ))))
The workflow of rhino is terribly slow compare to MOI, Michael make great job merging different commands in one! Also snapping...
I also watching tutorials on Rhino where they made some stuff for 15 minutes, that I made in MOI for 5 minutes)) So i'm addicted)) It's true. It's good to be addicted to something really good)
Rhino is like 3Ds Max or Maya... Big enormous monster... That was layered with new staff years after years, and save up all problems and mistakes that is not possible to fix without drastically changing it. It's like big pile..
  More Options
6076.31
Dont want to break the humor here, but this mesh fusion is really hot ! (and I'm affraid it makes the first video no valid anymore).
  More Options
6076.32 In reply to 6076.31
PaQ,
I think it's valid!
Because what you can make after you converted your object in mesh with Groboto, what??? Nothing except the sculpting.... Good base mesh for further sculpting... The cage is dense it is hard to work with this with standard polygonal tools except some kind of brushes. May be there is some option to control amount of polygons I did not see it in videos. But Any way after it becomes mesh you loose all that booleans advantages that you had...
With MOI I can do with model everything I want in any time. And after that export it in poly model..
So is it everything so cool like it on videos for serious projects? I think no.
  More Options
6076.33 In reply to 6076.31
Here's a better resource for video's on it. This is Darrel the developer. It is quite MORE than Booleans...
(Did he just push/pull a fillet?)
  More Options
Show messages:  1-13  14-33  34-53  54-73  74-93  …  114-119
