Vertex Normals
 1-17  18-27
6069.18
Interesting..
in middle of video you merge first re-topo object with original one from Moi? Is it right?Why?
If you can, tell more about this process,first time for me to see 3D Coat in action..i'm curious :)
M
6069.19 In reply to 6069.18
This process is for making low poly model (for games or animation).
Yes after retopo, I merged it with model from MOI. It necessary for creating normal map. This normal map repeats all details from high poly model and apply it to low poly model to have practically all details from highpoly.
So another words you have detailed low-poly model.
Portfolio: www.samardac.tumblr.com
6069.20 In reply to 6069.19
Many thanks,Andrei !
6069.21 In reply to 6069.20
Welcome)
6069.22
Andrei also started a thread for this tutorial the 3D Coat forum.
http://3d-coat.com/forum/index.php?showtopic=14879
AbnRanger, a contributor to the the 3D forum posted this in reply:
"Cool stuff. Thanks for sharing that demonstration. If you know the developer of Moi, it might be worth asking him to talk with Andrew or Stas about either an plugin for 3D Coat or some form of development within, to integrate the tools. I think there is some initial interest and exploration going on. I suggested to Stas, to consider MOI in some form. They are considering a separate version of 3D Coat that is tailored for manufactured output and 3D Printing."
6069.23 In reply to 6069.22
bisenberger,
Yep, will see what Michael say.
6069.24 In reply to 6069.23
That's really cool that they're considering a version for 3D printing.
What kind of additional integration between MoI and 3D Coat would you like to see? Since 3D Coat works on a much different kind of data than MoI, it's pretty difficult to do any bidirectional communication and it seems that 3D Coat has a good OBJ reader.
6069.25 In reply to 6069.24
>Good obj reader
what do you mean?
Now I can see only MOI to 3D Coat export automation. But it will skip only few steps. Can not figure out something more.
6069.26 In reply to 6069.25
Hi Andrei,
> what do you mean?
I mean if there is not any problem with the data transfer currently a plug-in isn't going to be solving any major problem.
If it only skips the steps of just doing a single menu pick in 3D Coat, that's probably a lot of work involved to save a very small amount of time.
If the integration gave some kind of benefit that you just could not do with the current file export, that would then be of more benefit and things that deliver more benefit tend to be better things to spend time on.
6069.27 In reply to 6069.26
Yep.
If will be some ideas i'll let you know.
Show messages:  1-17  18-27
