Nsided testing
All  1-3  4-7
6068.4
Here is OK Danny :)
6068.5
Thanks for testing guys, Nsided works for me also however there are inflections between some of the surfaces, I believe a Nsided surface should be tangent to each mating surface in this case it's not.
The reason I posted it.
6068.6 In reply to 6068.5
Hi Danny,
As far as I can tell it seems to be tangent to each mating surface, a Zebra stripe analysis of the default generated patch looks like this:
Note there how all the zebra lines touch each other across the boundary lines? That means they are tangent.
I can see what you don't like about the patch though - but it's not that it's not tangent though it's that there's a kind of build up of curvature in a relatively small area near by the outer edges of the patch. Currently the n-sided patch mechanism has a tendency to do that kind of shaping, I do want to try to explore some different ways to reduce it.
Sometimes tweaking the "Bulge" factor can help.
6068.7 In reply to 6068.6
Thanks Michael,
Just thought I'd put it out there so I know what is actually happening at surface to surface juncture while testing Nsided.
Show messages: All  1-3  4-7
