Line width.
All  1  2-5
6066.2 In reply to 6066.1
Hi Andrei, try leaving line width to 1 and instead set the option to use thinner anti-aliasing as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5961.2
6066.3 In reply to 6066.2
Thanks works good, but it looks like it a bit slower or flicker screen when I live 0.01 or it just illusion? With 1 works more smoother.
6066.4 In reply to 6066.3
Hi Andrei, yes probably if you set line width to less than 1 and then also enable thin antialiasing you may get some dropouts, it may be video card dependent.
Try leaving the width to the default 1.0 and only setting the use thin anti-aliasing setting.
6066.5 In reply to 6066.4
Something was wrong with my PC, it works good with .01 too)
With this thin lines it look awesome)! Thank you)
Absolutely different fill! Make it by default))
EDITED: 26 Jul 2013 by ANDREI SAMARDAC
Show messages: All  1  2-5
