cruise ship hulk
 1-2  3-22  23-42  43-44
6054.3 In reply to 6054.2
Andrei:you are "the Star" now :) so give a hand to him ! (i'm joking)
6054.4 In reply to 6054.3
M-dynamics, I can give a hand if the model has some kind of challenge.
But this has no any tricky parts. A lot of simple geometry)
Portfolio: www.samardac.tumblr.com
6054.5 In reply to 6054.4
..nooo..you are really a TRUE star :) :)
(you remind me Dr.House....)
else you have a very cool prog specialized in Boats (maybe not so ergonomic than moi ;)
with subdivision of surfaces!
http://www.delftship.net/delftship/index.php/delftship/delftship-free
EDITED: 23 Jul 2013 by PILOU
6054.7 In reply to 6054.5
M-Dynamics in every your post that applies to me I see some kind of sarcasm. Сorrect me if I'm wrong.
6054.8 In reply to 6054.1
Hi Mike, is it the hull that you're focused on first?
There are some links to different discussions on ship hull modeling gathered here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3814.1
Some of that information may help.
6054.9
Hello Mike,
While it is Rhino specific you might pick up some good pointers and tutorials from this link:
http://rhinocentre.blogspot.com/search/label/15%20Marine%20Design
Hope it helps.
6054.10
Andrei no sarcasm :) ...it's opposite !
I just have thought to use your energy and enthusiasm to give some tips quickly,you're very fast with your method
That's why i invite you ;)
Pace-Mir !
M
A long time ago, pre-MoI useage, with Alibre, I arduously did a canoe with gunnel curves, keel curves, estimated cross sections,
and loft(s). Google has deck plans.
6054.12
thanks all for your tips! (almost all)
Usually I'm modelling in C4D and can handle well all kind of shapes normally!
But I never built a ship-hull and without having exact blueprints
the tricky part for me is to get a "clean" surface in the area, where the curvature/bend
starts from the straight side to the nose. This bend is along a diagonal line and
always looks inaccurate.
I have a reference which I have to rebuild as exact as possible, but only from the side view.
I'll keep on trying!
thanks
Mike
6054.13
These may help: (found on net - searched for "Holland America Ossterdam Deck Plans")
Not sure their in proportion or even of the same ship...
Oooh, a good side view:
6054.14
Hull - 5 Minutes work)
Have no blueprints, just made it to show you the mehtod.
If you are not going to build real ship from this model, but made it for render or 3D printing this method for you)!
Loft (loose, exact)
Project:
https://docs.google.com/file/d/0B9EKfPF6omtHTEtrd19wYjZQTjA/edit?usp=sharing
EDITED: 24 Jul 2013 by ANDREI SAMARDAC
Cool!
Lofting in the sea!
In French "lofer" is to luff on the waves! :)
6054.16 In reply to 6054.15
Pilou, cool analogy :))
6054.17
Hi Andrei,
cool! Thanks very much!
I tried all the time with loft-curves in the other direction (from rear to front)
Maybe that made me such troubles. Your workflow seams to produce
smoother results in that bulge areas.
thanks
MIke
6054.18
Hi Mike,
thanks for the images!
I got deck-plans for my ship, but they don't cover
the ship hull entirely like in your example (only to the middle of the hull)
They are helpfull for the building, but not for the hull.
thanks!
MIke
For the Vista class cruise ships, of which there are about 17, searching google for "(sister ship names) dry dock photos,"
brings up some nice pictures of the bow, a few of the stern, some aerials, and scads of interiors.
The bulbous thing on the bow, bow thrusters, and stern are impressive.
6054.20 In reply to 6054.17
Mike, no problem)
6054.21
Very cool Andrei...I really like your method and it provides a whole new dimension to MOI (especially if Michael adds the loft to point).
One question....Do you use the normal or loose option in your loft method?
Thanks!
6054.22 In reply to 6054.21
Niko, Thanx)
I use only - Loose. Normal will not able to get this Sub-D like deformations.
Also use Exact. For example this hull was modeled with Exact. Other function do not work good in different cases.
Michael is going to add loft to point, it will good upgrade.
I have some thoughts on how to make loft more advanced or may be make alternative version of MOI -Freestyle, where Loft will be on the first place, like push/pull in Sketch Up. It will have less commands and cost cheaper. But Michael works one and it's hard for him to lead 2 projects.
Also I'm afraid that Michael is not very interested in this not precise method. He concentrates more on CAD type modeling tools.
But I think there is a lot of users from Art department where precision is not so critical and they will be glad to use moi for their needs. With it's ability to export different polygonal cage it can be very useful for game creating assets especially in hard surface.
Any way, MOI now has all tools that is absolutely enough for me. And all that I said above is just thoughts that may be not very good:))
Show messages:  1-2  3-22  23-42  43-44
