Request for the next beta !!
6051.1
hi,
If possible to see the polysurface open borders join and not solid (type rhinoceros).
And set the tollerance unit type rhinoceros for nurbs operations ?
Marco
6051.2 In reply to 6051.1
Hi Marco,
It's possible to see "naked edges" in the current version by setting up a script on a shortcut key. To set it up, go to Options > Shortcut keys and push the Add button to add in a new entry at the top of the list. In the key column put in N and for the command column paste in the following:
script: /* Highlight naked edges */ var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
Then when you push N the naked edges in your model will get highlighted so you can see them.> And set the tollerance unit type rhinoceros for nurbs operations ?
You can currently set the unit type under Options > General > "Unit system". If you want to set the default units at program start up, push the "Unit options" button on that same dialog and there's an option for that there.
6051.3 In reply to 6051.2
Thanks Michael
Unit ok but the value type image attachment.
Marco
Size: 62.6 KB, Downloaded: 934 times, Dimensions: 631x553px
6051.4 In reply to 6051.3
Hi Marco - the tolerance in MoI does not work quite exactly the same as in Rhino. In many areas MoI uses an "adaptive tolerance" where it's based on a fraction of the size of the objects involved rather than just fixed at one individual hard coded value.
There are still some areas where MoI uses a fixed tolerance, and for those areas it uses a value of 0.001 units, there is not currently any way to adjust that.
What in particular are you trying to do where you want to adjust the tolerance value?
6051.5 In reply to 6051.4
Ok Michael
I happened in some cases the union of surfaces
Important would see different color surfaces with normal inverted priam applying the command "flip"
Thanks for everything and I hope soon to see the new beta
Marco
6051.6 In reply to 6051.5
Hi Marco,
Do you mean that you wanted to adjust the tolerance for one specific boolean union? Can you please send the 3DM file to me with the objects to be unioned inside of it so I can take a look at what is failing?
In the future I do want to add a display mode for showing back facing surfaces.
But what is the reason you were needing to use the Flip command in the first place?
6051.7
What ist this flip command?
6051.8 In reply to 6051.7
Press Tab then write Flip! :) or flip but without space!
My Moi French Site My Gallery
6051.9 In reply to 6051.7
Hi Rudl,
Some information on it here:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#flip
6051.10
Thank you.
