> Say I am inside the menu Grid
> Button "Restaure defaults" restaures the current menu Grid or all the menus? View Grid Snap etc
> and about ShortCuts ? all are erased except default in case of a presume general reset?
> It's for that i have never pressed this button! :)
When you push the button a secondary dialog pops up that asks whether you want to restore defaults for the current section only or for everything:
If you have the grid section of the Options dialog open and then push "Current section only" on that dialog, only the grid settings should be reset.
It's probably not a bad idea to make a backup of your moi.ini file first before doing that anyway though, just in case. To make a backup, go to %AppData%\moi and make a copy of the moi.ini file in there.
