Any script to weld line points?
6024.1
Hi, the client gave me a .dxf file but many lines (not polylines) are not touching each other for like 0.1 mm, and I need to make them touch by hand in order to join them and to extrude them. Is there any script or suggestion to make like a general welding, given a tollerance?
Thanks in advance,
M.
6024.2 In reply to 6024.1
Hi wastzzz, sorry I do not know of any script or automated process in MoI for doing that kind of cleanup. It tends to be difficult for an automated process to deal with big heaps of line segments particularly when there may be spots where 3 or more line segments come to a common juncture point.
Maybe if you have a polygon editing program available you can import the DXF file into the polygon editing program, do a "merge vertices" in there, and then export that back out as a DXF again, or if the polygon editing program will only export polygon data and not lines back out to DXf, instead export out to OBJ format and then use the OBJ to 3DM converter from here: http://moi3d.com/wiki/Resources#Obj23dmWireframe_converter
6024.3 In reply to 6024.1
If you can post a sample here I'd like to look at it and see if I have any help.
6024.4 In reply to 6024.2
Thank you for your input, actually I also own 3DSMax which has indeed a way to weld vertices of splines.
