cannot open V3 beta
All  1-4  5-6
6022.5 In reply to 6022.4
Hi Rudy, I'll send you the utility but you shouldn't use it until you're all done switching your clock around and can leave it set to the current date. You can't really run the v3 beta properly without the date set correctly and if you're changing the date back and forth a lot you'll just run into the same problem again, and also the beta reset utility will only work one time so you'll want to be finished doing clock stuff when you use it.
6022.6 In reply to 6022.4
Thank you Michael,
got it.
Rudy
Show messages: All  1-4  5-6
