Customize my Moi3d software
 1-7  8-27  28-29
6020.8 In reply to 6020.6
Hi Nikola,
> With your promission I can create a small tutorial for the community members on
> how to create their own customizations.
Certainly, that would be great!
> I'm just wondering when there will be surface match tool in moi3d.
I don't really know myself yet. One problem is that I'm not sure that it will be feasible to combine it as a different mode or something in an already existing tool. Things that require totally new tools need a lot of thought for where to place them in the UI.
6020.9 In reply to 6020.8
<I don't really know myself yet. One problem is that I'm not sure that it will be feasible to combine it as a different mode or something in an already existing tool. Things that require totally new tools need a lot of thought for where to place them in the UI.
My suggestion would be to place surface match with blend tool when you develop it.Also it could be useful as script to call it with shortcut.Thanx for your reply,I really appreciate your effort.
Now I will continue to customize my moi UI.As soon as I find it everything pleasing to the eyes I will post it on forum.After that I will create a small tutorial for other members who wish to customize their moi.
Best Regards from Nikola
6020.10 In reply to 6020.9
Hi Nikola,
You mean next to the Blend tool or as a different mode inside blend?
One problem with that is the current way the UI is organized, the "Construct" tools (where Blend is) are basically tools that generate new objects. Match surface is sort of more like editing an surface rather than constructing a new one.
It may be something that I'll end up putting on some kind of "advanced edit tools" type secondary menu rather than directly in the side pane...
6020.11 In reply to 6020.10
For me blend tool in moi is the best tool for gluing surface,so that is why I thought it would be nice surface match to be next to the blend,but also it could be in new section as you suggested.For me it is important that it will be implemented some day and I'm looking forward to it.
Here is my progress with moi UI customization.I can't find some elements,but I will be persistent and will focus on it.
EDITED: 10 Jul 2013 by ZENOX3D
6020.12 In reply to 6020.11
Hi Nikola, those buttons at the bottom of the Options dialog are <moi:PushButton> elements, in moi.css search for PushButton to find the section that has their styling in it. The push button element is a templated element which means it expands to have some additional HTML tags inside of it, the inside HTML is defined by the file PushButton.htm that's in the same ui folder as moi.css . It basically just has a nested div element inside of it that has the border decorations on the nested div, so it's a little easier to have some padding around the border.
If you want to adjust the text color of those elements, go to the moi\:PushButton { } rule in moi.css and inside that rule add a color: property like color:black; to set a different text color for push buttons.
Hope this helps!
6020.13
I also customized my UI, basically by desaturating everything :p
6020.14 In reply to 6020.12
Thanx for your help I found and changed it.Here is my suggestion for that buttons.What do you think?Or maybe I should continue with bluish and gray shades.
It looks nice and it is visible to the viewer.I will keep experimenting with colors.Maybe I will try with gray gradient shades.Thanx again for you quick reply.
6020.15
Michael... now if we could place a bitmap in the background, my MoI would take on a campy but oh so 'coool' theme.
6020.16 In reply to 6020.14
Hi nikola,
It kind of looks a bit like one of the video games I used to play on my Commodore 64 a million years ago... :) You should just go with whatever you like best!
6020.17 In reply to 6020.15
Hi Mike,
You can do that - copy your image into the \ui folder, then you can apply it as a background image to any element by using this css:
background-image:url(moi://ui/icee-964891.jpg);
So for example inside of Options.htm right before the end of the <style></style> section, put in:
     <html>
          <head>
                <style>
			body {
                </style>
And that will make an options dialog that looks like this:
6020.18 In reply to 6020.17
Oh... The wheels are a turnin'! =-)
Thanks. I might first try a textured pattern to give the UI a tactile feel.
6020.19 In reply to 6020.1
Hello,
Here is the latest screenshot of my customized moi UI.It's almost morning,and I will now go to sleep before I create some mess in my customizing.I hope you like it.
Regards from Nikola
6020.20
Quite attractive!
6020.21 In reply to 6020.20
Thanx MajikMike I'm giving my best to be visible and attractive.Here is my latest update.
6020.22
It might just be my old eyes, but I find the orange buttons that have graduated brightness are quite difficult for me to read. The blue calculator buttons are much clearer. Overall, I really like what you've done.
Martin (2).
6020.23 In reply to 6020.22
I will put today this version with orange and blue combination.But also I will create with blue gradients as you asked in your post,if the orange gradients still distracts your eyes.I'v got used to css coding from moi,so I can now easily change and find what I need.
Regards from Nikola
Does this sort of customisation is previewed in the future versions of Moi, or it's just a sort "plugin" ?
6020.25 In reply to 6020.16
I almost finished my moi3d customization.I have only unsolved the elements on screenshot.It is the last piece of the puzzle.When I fix that I will post my css file on forum.I must admit when changing codes I accidentally erased this sign "}" and moi crashed.I was pretty scarred,but I'v quickly found the error and fixed it.Thanx in advance for your reply.
Kind regards Nikola
6020.26 In reply to 6020.25
Hi Nikola, that menu that you are showing there comes from the file StyleMenu.htm , and if you look in there you'll see on the body tag it has: <body class="MenuBodyDark"> so to adjust the gray color on some flyout menus like that you would edit the background-color attribute on the MenuBodyDark class inside of moi.css, it's near the top of the moi.css file.
6020.27
Hello Michael!
First of all I would like to thank you for this awesome software that you have developed over the years! It truly gives a different and unique experience in 3D modeling! :)
So, since I saw many customers are able to modify the UI elements of the MOI, I was wondering is there a way I can incert a line of code and get a Viewport color gradient effect?
Thank you in advance!
Show messages:  1-7  8-27  28-29
