Customize my Moi3d software
 1  2-21  22-29
6020.22
It might just be my old eyes, but I find the orange buttons that have graduated brightness are quite difficult for me to read. The blue calculator buttons are much clearer. Overall, I really like what you've done.
Martin (2).
6020.23 In reply to 6020.22
I will put today this version with orange and blue combination.But also I will create with blue gradients as you asked in your post,if the orange gradients still distracts your eyes.I'v got used to css coding from moi,so I can now easily change and find what I need.
Regards from Nikola
Does this sort of customisation is previewed in the future versions of Moi, or it's just a sort "plugin" ?
6020.25 In reply to 6020.16
I almost finished my moi3d customization.I have only unsolved the elements on screenshot.It is the last piece of the puzzle.When I fix that I will post my css file on forum.I must admit when changing codes I accidentally erased this sign "}" and moi crashed.I was pretty scarred,but I'v quickly found the error and fixed it.Thanx in advance for your reply.
Kind regards Nikola
6020.26 In reply to 6020.25
Hi Nikola, that menu that you are showing there comes from the file StyleMenu.htm , and if you look in there you'll see on the body tag it has: <body class="MenuBodyDark"> so to adjust the gray color on some flyout menus like that you would edit the background-color attribute on the MenuBodyDark class inside of moi.css, it's near the top of the moi.css file.
6020.27
Hello Michael!
First of all I would like to thank you for this awesome software that you have developed over the years! It truly gives a different and unique experience in 3D modeling! :)
So, since I saw many customers are able to modify the UI elements of the MOI, I was wondering is there a way I can incert a line of code and get a Viewport color gradient effect?
Thank you in advance!
6020.28 In reply to 6020.27
Hi Edd, I'm glad that you are liking MoI!
Unfortunately, sorry no there isn't any way to modify that particular thing - the viewports are drawn using a separate mechanism from the other parts of the GUI like the toolbars and buttons, the viewports are not controlled by HTML and CSS like those other areas are.
You can change the solid background color of the viewports but there isn't any way to add a gradient effect instead.
6020.29 In reply to 6020.28
That is totally fine Michael, Thank you anyways!
Show messages:  1  2-21  22-29
