Configuring Viewports
6011.1
Is it any way to make for example only to views front and 3d?
Portfolio: www.samardac.tumblr.com/
6011.2 In reply to 6011.1
Hi Andrei, sorry no there's not currently any way to change the split view to be other than 4 viewports in it.
6011.3 In reply to 6011.2
Good)
6011.4 In reply to 6011.3
Michael is it any way to hide back points? Something like cull back faces.
6011.5 In reply to 6011.4
There isn't anything for back-facing point culling, just in general surface control point editing is not really a focus area for MoI. I mostly assume that if you're doing a lot of heavy surface control point editing that you would be doing that in a sub-d modeling program instead of in MoI. So curve drawing and construction techniques are more what things are generally focused on.
Control points that are behind shaded surfaces are drawn with transparency so they're fainter, but there isn't any way right now to control the level of transparency.
6011.6 In reply to 6011.5
I think you do not need to refer to sub-d in this area. I modele now helicopter and made body totally from points.
It's great part of nurbs, I personally dont like sub-d. Think a lot of people too) So I think you have to support this things in moi)
6011.7 In reply to 6011.6
It can generally be awkward to do a lot of surface control point editing with NURBS because you can't just insert a single individual point somewhere in a surface, a NURBS surface is defined by a UV grid of points with rows and columns in it. So when you add points you have to add an entire row or column of them, not just one single one.
Because sub-d modeling allows more arbitrary connections of points makes it usually more suitable for surface point manipulation.
In the future I will be adding more stuff for editing surface control points in MoI but since it's just not an area that NURBS are particularly strong in it has not been a focus area yet - I'm still much more focused on areas where NURBS are particularly powerful in like construction from 2D curves and boolean operations.
6011.8 In reply to 6011.7
Michael<<In the future I will be adding more stuff for editing surface control points in MoI>>
..T-Splines??...Clayoo..??.. :)
6011.9 In reply to 6011.8
Well there I was talking about just regular NURBS surface control point editing, like more tools for selecting points, stuff like that.
6011.10 In reply to 6011.9
Michael..you know..i just can't stop "that dream" ;)
Message 6011.11 deleted 5 Jul 2013 by ANDREI SAMARDAC
Message 6011.12 deleted 5 Jul 2013 by ANDREI SAMARDAC
Message 6011.13 deleted 5 Jul 2013 by ANDREI SAMARDAC
Message 6011.14 deleted 5 Jul 2013 by ANDREI SAMARDAC
6011.15
Michael when doing loft, any point weights applied to it? Or all points are the same weight?
6011.16 In reply to 6011.15
Hi Andrei,
It depends on the "Profiles" mode that's being used for the loft. Usually the profiles will be refit by curves so that the profiles are matched up by the distance traveled along each curve and not squished or stretched depending on control point spacing. So by default it's influenced more by the overall shape and length of the curve and not by any individual control points.
