Merge precision
All  1-7  8-14
Is that normal?
A plane + a circle (on the plane) give with boolean "merge" a minimum height to the circle?
( here I have erased the "center disc" result on the "front piece")
Ps Same result when the circle is over the plane
EDITED: 10 May 2007 by PILOU
601.9 In reply to 601.8
Hi Pilou, this one is definitely a bug, thanks for reporting it!
The bug is in how non-volumetric surfaces are handled in combination with auto-extruded curves. I've fixed this for the next beta so it will work in the expected way.
601.10
hello all :)
thank you Pilou :) for the merge functions info.
ciao
torolf
601.11 In reply to 601.10
Cool research !
yes crazzy forms can be made with a minimum effort with the "merge" function :)
EDITED: 13 May 2007 by PILOU
Is that normal? (it's a same curve // but more long for the second)
I suppose yes but...
601.13 In reply to 601.12
Hi Pilou, it is normal for this type of situation to fail.
It would be nice if it could work, but handling self-intersecting objects becomes much more difficult. Generally if a curve or surface folds and intersects itself it will not work properly for operations that involve calculating the intersections between objects.
601.14 In reply to 601.13
Thx : It that I had supposed but want to be sure :)
Show messages: All  1-7  8-14
