Rebuild Curve Minimum
All  1-2  3
6007.3 In reply to 6007.1
Hi Marc, the number of points that you specify in Rebuild is actually the number of sample points that are used for the interpolation process, then the interpolation itself ends up using one additional control point on each end because of how it preserves the start and end tangent directions of the original curve.
If it were to work with making only one single interior point like you're describing, that would then not be able to preserve the tangents like it is currently doing.
Show messages: All  1-2  3
