A quick (and dirty) Script Palette script
 1-17  18-37  38-44
The only default that I see is that you must create a different Shortcut for each item even you don't need it if you want just use the text palette!
use the same shortcut for different commands don't work! :(
an empty Left column don't work :(
Or does exist a little trick for avoid that ?
Curiouslly something like
Alt + 1 + 2 Cone /*?cona*/
Alt + 1 + 3 Rectangle /*? rectangla*/
Alt + 1 + 4 Lines /*?Ligna*/
...etc
Close Options Shortcut, Exit Moi
works only at the first re-launch of Moi! Cool... :)
...but not at the second re-launch! :(
And disapears from the Shortcut list!
(words following are just letters not real French words except "Tuber" = Sweep and "Fermer" = Close ! )
EDITED: 16 Feb 2014 by PILOU
5993.39
Hi Frenchy!
I had the same result.
But there are some more of "!". Replace all with "?" and the ":)" comes back.
Hans
5993.40 In reply to 5993.39
Yes but the number of possible ShorCuts are dramatically decreasing if you want keep some ones for real typing ShortCuts !
5993.41
>> And disappears from the Shortcut list!
Found another little trick:
Create copies for each category. For example one for spirals, '../ui/ScriptSpirals.htm'
Change Line 22 to utilize a different character, unique for each category, as the '?' had been suggested: title = line.match(/\/\*\?(.+)\*\//);
[Shortcut Keys]
Alt+1=script: /*!Spirals...*/ moi.ui.createDialog( 'moi://ui/ScriptSpirals.htm' );
Alt+2=_ArchimedeanSpirals_ /*?ArchimedeanSpirals*/
Alt+3=Logarithmic2D /*?Logarithmic 2D*/
Alt+4=EulerSpiralSlider /*?Euler Spiral*/
Alt+5=EulerSpiral3 /*?Euler Spiral v3*/
Alt+6=FrenetClothoid3D_RK2_v1 /*?Frenet Clothoid 3D*/Alt+DownArrow=Nudge Down Small
A=Join /*!Join*/
Alt+S=IncrementalSave /*!Incremental Save*/
Ctrl+R=ReBuild /*!ReBuild*/
Ctrl+Shift+S=ScaleArray /*!ScaleArray*/
G=SpurGearProfile /*!Spur Gear*/
z=script:moi.ui.createDialog( 'moi://ui/ScriptPalette.htm' );
This way, items from the first list can 'createDialog' for other sub-categories:
And since each category file parses the ini file separately, the process remains repeatable!!
Even though, there are still yet a finite number of key-codes available for listing.
EDITED: 25 Apr 2015 by IGNITER
5993.42
Hello all,
I try to use that fine script with Moi 2.0 (Win7 64bit) but it just wont work. Giving me an error message (see attachment).
I made sure the ScriptPalette.htm is in ui folder NOT in Commands folder.
Can anyone help?
Rogurt
5993.43 In reply to 5993.42
Hi Rogurt,
unfortunately i don't think this script will work with Moi 2.0
I've never used Moi2.0 as i'm on a Mac, but there was a big change from Moi2.0, which was using Internet Explorer, to Moi 3.0 which is using webkit.
Dinos
5993.44 In reply to 5993.42
Hi Rogurt, that script is using some new functions that were added in for v3, so it requires v3 to run and won't work on v2.
Show messages:  1-17  18-37  38-44
