A quick (and dirty) Script Palette script
 1-12  13-32  33-44
5993.13 In reply to 5993.12
Of course I can try some files of different arborescences but I prefere than an expert tell me the good file directly, it's more prudent! :)
French Version! (before the French version of the button! :)
http://moiscript.weebly.com/palette-de-scripts.html
Ps Does it possible to make several palettes ?
EDITED: 6 Feb 2014 by PILOU
Finally got the script to work, after following the directions :-)
Note, there cannot be a space before the !
5993.15
Hi Frenchy.
Thanks for the french version! :-)
There is no easy way to make than one palette. You could make a copy of the script with a different name and change the ! in the code to something else for the second palette, but it would make it an even bigger hack than it already is.
The close button is just the standard moi:DialogClose tag. I'm not sure if this localized along with the rest of Moi3D if you are using a different language.
I remember looking for a way to close the Dialog window after a command is selected, but i couldn't find one. That would eliminate the close button altogether and improve the operation of the script.
5993.16 In reply to 5993.11
Frenchy,
It is working from the English strings "; Common dialog buttons Dialog close button=Close".
I don't know why it is not translating with the French strings. It could be the way the filesystem is called in the script? I think Michael will have to look at this.
5993.17 In reply to 5993.9
> What file must have to edit for have French "Fermer" against
> the English "Close" button?
Just make sure you have your Language set to French (Options > General > Language), then the dialog should show this (screenshot from my system with MoI language set to French):
This was with the current v3 version, are you maybe using an older version Pilou?
5993.18 In reply to 5993.16
Hi Burr,
It's working fine for me over here - when I set Options > General > Language to French, I get a French language close button, as shown above.
You can even have the dialog open when you change the language and it updates dynamically as the current language is switched...
Do you see something different than that over there?
I was testing using the current v3 beta - Pilou are you using an old version maybe?
5993.19 In reply to 5993.15
Hi dinos,
Yup, it is localized and the localization seems to be working fine for me over here...
Buttons or menu items on a flyout will automatically dismiss the flyout when pushed, but that built in default auto closing won't happen if they are on a dialog instead of a flyout menu.
You can add an onclick="" handler to make the dialog close though, you'd want to do the same thing as the button inside of the DialogClose.htm template, which is: onclick="moiWindow.endDialog(0);"
So modifying line #26 of ScriptPalette.htm to be this should do it:
				html += '<moi:MenuItem onclick="moiWindow.endDialog(0);" command="' + cmd + '">' + title + '</moi:MenuItem>';
For some people it might be good to have a separate close button if they are using it repeatedly though...
5993.20 In reply to 5993.18
No. I just did a test by changing the English strings text and didn't switch my system to French.
I just assumed Frenchy new this and it wasn't working for him, and wanted to point him at the area that controlled that dialogue text.
5993.21 In reply to 5993.19
Hi Michael.
Thanks for your help. I've updated the first post to include 2 versions of the script: one with a close button and one without.
Personally i prefer the version without the close button as it feels more natural: Shortcut for the popup to appear, command or escape to dismiss.
But i'm sure there are cases where it might be more useful to have a close button.
Dinos
EDITED: 6 Feb 2014 by DINOS
Perfect : I had not enabled the French Language! :)
So when I enable it magically "Fermer" appears as aspected!
Sorry for the little disturb!
Of course I had also the red x button! ;)
5993.23 In reply to 5993.22
> Perfect : I had not enable the French Language! :)
Mystery solved! :)
5993.24
Why I can not to have this script correctly shown in window?
script: /*! Show all except curves, points and Hidden style*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle("Hidden",0), sti; if (st) {sti = st.index;} else { sti = "nf";} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
In script window it looks like this:
< obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};"> Show all except curves, points and Hidden style
Looks like it becouse <.
5993.25 In reply to 5993.1
Is it any way to make some categories in this script window, to store scripts more logically?
5993.26 In reply to 5993.24
Hi Andrei,
The problem is caused by the double quotes around "Hidden" and "nf" in the script.
If you replace the double quotes with single quotes it should work fine:
script: /*! Show all except curves, points and Hidden style*/ var obj = moi.geometryDatabase.getObjects().getBReps(), st = moi.geometryDatabase.findstyle('Hidden',0), sti; if (st) {sti = st.index;} else { sti = 'nf';} for ( var o = 0; o < obj.length; ++o ) { if ( obj.item(o).hidden && obj.item(o).styleIndex !== sti) { obj.item(o).hidden = false; obj.item(o).selected = false; }};
This is a limitation of the way the script palette works.
Dinos
5993.27 In reply to 5993.26
dinos, thank you.
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
Works fine for the "one line" but for the "commands" I see well the name of the Line of the Command but
A little problem!
Of course the command works when I make : Press TAB ...and type _vClone !
Idem if I take a direct native command like Blend!
EDITED: 14 Feb 2014 by PILOU
5993.29 In reply to 5993.28
Hi Frenhcy,
you have to leave a space between the command and the comment:
Blend /*!Blendo*/
Otherwise my script and/or Moi get confused.
Dinos
5993.30 In reply to 5993.29
aaaaaaaaaaaaaaaaaaaaaaaaaaaaah!!!!!!!!!!!!!!
All is fine now! Bravo!
5993.31
Hi dino!
You use this sign "!" to pick the commands for your palette. In your script I have seen some of this sign.
Can i change this signs for example in to "?" or other?
Then copy and rename your script "Script Palette 2" to make different category of caommands.
I am not a programmer. May be this is a way.
Thanks for your work!!
Hopefully, Hans
5993.32 In reply to 5993.31
Hi Hans!
I havent tried it, but yes it should work as you describe.
Just change the ! at line 22 in the second copy of the script to something else:
title = line.match(/\/\*\!(.+)\*\//);
Its escaped so you should be fine with most symbols.
I wrote this script primarily for me, and released it in case someone else needed a relatively simple way to keep their scripts in a palette. The Shortcut Keys panel inside Options is hardcoded and cannot be altered so i used the ! sign to emulate a check box next to each command. In my mind the ! sign is actually a check box saying "include in the palette" ;-)
I could replace the ! with !1, !2 etc for multiple categories, but there a few issues that i'll have to think about such as naming the categories, passing parameters to the script etc.
If i can find some free time i might give it a shot.
In the meantime what you are describing is the best way to do it.
Dinos
Show messages:  1-12  13-32  33-44
