Surface Pro
All  1  2-7
5980.2 In reply to 5980.1
Hi Pilou, MoI should work fine on the Surface Pro. I'm not sure that I have heard from anyone using one with MoI yet though.
One thing to be aware of is that the Surface "Pro" is very different than the Surface "RT" - the "Pro" version is a regular Windows 8 machine, while the RT one cannot run regular Windows programs.
5980.3 In reply to 5980.2
Yep
And I see that (Moi has no pressure level? Yes ?)
Surface Pro has that "Windows Inbox Drivers and API" for moderne UI
This API can have 2048 pressure levels
But graphic progs have just now an old one « WinTab API »
With the last drivers Wacom can read this old « WinTab API » so also 2048 pressure levels
But this Surface Pro with its technology "Feel IT" can have just 256 pressure levels
maybe it's not so bad if you see the video above
5980.4 In reply to 5980.2
I use MoI on my Surface Pro. Works great.
5980.5 In reply to 5980.3
Hi Pilou, MoI does not use pressure sensitivity for anything itself, so number of levels is not important as far as using MoI is concerned.
5980.6 In reply to 5980.5
Thx for all the infos!
About the pressure seems you can have 1024 ;)
Show messages: All  1  2-7
