Copy enhancements
All  1-3  4-6
5976.4
Thank you for the explanation. I've used those functions and they work really great but this is an easier way to get there because it is inside a frequently used command and you need less clicks.
5976.5 In reply to 5976.4
Hi ed, the problem is that if implemented the way you are describing it would be very hidden since there would be no visible UI to activate those particular features. And since the array dir command already does exactly the same job it just doesn't really seem to be necessary to add in a duplicate place like that...
On top of that it's actually more difficult to add it in the way you are describing than what you might think, because the Transform > Copy command does not itself have any already existing input field of its own for entering that optional * or / text, it would have to try and hook into the x,y,z coordinate entry box or something like that I guess, there is not anything set up for that currently.
5976.6
Thats true, thank you for your patience!
Show messages: All  1-3  4-6
