Hi Henrick, is it possible that all your objects have a name attribute on them and they all have the same name?
I believe that Cinema4D automatically combines objects with the same name together into one single big object, that may be what is going on there.
Try clearing the name attribute when in MoI, when you export totally unnamed objects MoI will auto name them like "object 1", "object 2", etc... so they should be separately selectable then.
You also might try using OBJ format instead of FBX format if you still see problems with FBX format.
To clear the object names, do a "Select all" (ctrl+a) and then click on the name field in the object properties panel here:
After you click there, an "Edit name" dialog will pop up, push backspace to remove the name and push "OK" with the name field empty and that will remove the name property on all those objects and they should then get auto named with separate names at export time.
