Planar quadrangles
 1-8  9-28  29-33
5959.29
hallo FP,
lineweb did not make planar quads. It was just for orientation.
Rudl
5959.30 In reply to 5959.29
Hi Rudl, yup that's right - LineWeb just makes a bunch of lines, and just having any 4 lines connecting end to end does not by itself mean that they are planar.
It sounds like you have taken all of this into account now with your final result though, I'm glad you were able to finish it! :)
5959.31
yellow is lineweb.
5959.32 In reply to 5959.29
Works if each side have the same measure! (so I can't obtain exactly the same result than your :(
And polyline N°1 is rotated from an external center!
Each facet is planar but Planar function itself can't work for all facets in one click because some segments are not doubled! :(
EDITED: 18 Jun 2013 by PILOU
5959.33 In reply to 5959.32
Hi Pilou, yes for the special case where each polyline that you created like that is an exact copy of the other and only rotated that will work, but that's pretty different than just running line web on a series of general curves. In the general case doing lineweb between any kind of smooth curves you will not likely get planar results.
Show messages:  1-8  9-28  29-33
