Planar quadrangles
 1-2  3-22  23-33
5959.23
I meanwhile have found this soluion.
5959.24 In reply to 5959.23
Looks good Rudl! Just be careful - only having 4 lines on the outside of a surface does not just by itself make a surface to be planar. If you're using a construction tool like sweep or network to build a surface between any 4 lines it's pretty easy for that surface to be warped in some way instead of being flat.
If you created all those surfaces by using Construct > Planar or Draw solid > Plane then it should be ok though.
Bravo!
As always, that was very simple but some headache for find it!
And that is "cutting" diamond!
And Lineweb works fot that! ;)
In twice for special threatment for the top!
5959.26
The lower rows I made with plane through 3 points, scaled them up, intersected them and trimed them. The top I made with a polygon and filled it. I had a lot of try and error, finally the sequence was important.
Rudl
5959.27
Yes, lineweb helped. It was a mixture of the suggestions I got.
5959.28 In reply to 5959.27
5959.29
hallo FP,
lineweb did not make planar quads. It was just for orientation.
Rudl
5959.30 In reply to 5959.29
Hi Rudl, yup that's right - LineWeb just makes a bunch of lines, and just having any 4 lines connecting end to end does not by itself mean that they are planar.
It sounds like you have taken all of this into account now with your final result though, I'm glad you were able to finish it! :)
5959.31
yellow is lineweb.
5959.32 In reply to 5959.29
Works if each side have the same measure! (so I can't obtain exactly the same result than your :(
And polyline N°1 is rotated from an external center!
Each facet is planar but Planar function itself can't work for all facets in one click because some segments are not doubled! :(
EDITED: 18 Jun 2013 by PILOU
5959.33 In reply to 5959.32
Hi Pilou, yes for the special case where each polyline that you created like that is an exact copy of the other and only rotated that will work, but that's pretty different than just running line web on a series of general curves. In the general case doing lineweb between any kind of smooth curves you will not likely get planar results.
Show messages:  1-2  3-22  23-33
