MOI3D as an archviz tool
All  1-4  5-11
5955.5 In reply to 5955.3
Hi Marco,
For this building my job is to add paneling and other stuff on top of existing geometry.
I received an autocad file (really ugly with a lot of errors), I exported parts of it in .SAT
Imported the .SAT files in MoI and cleaned them (removed back faces for performance at render time)
Then separated each faces of the building because it was too big to handle even for MoI 3D (even with 4gb of GPU memory...)
I added some stuff (still need to add more) inside MoI 3D (thanks to the awesome copy tool and linear arrays)
Then I export everything in separated OBJ files and import in Cinema 4D
Rendering is done inside Cinema 4D with the Maxwell Render plugin
Panels material is based on real samples (scan then made tileable using pixplant)
Now I need to make every panel a little bit different from the others and simulate shades in the windows and even fake interiors for closeups :)
shapenoid.com stojan-voumard.com
5955.6 In reply to 5955.5
ah, thank you. that's pretty straight forward.
-marco
5955.7 In reply to 5955.6
Little update, please don't share the link outside this forum :)
https://dl.dropboxusercontent.com/u/44982094/ECOVER%20BOSSONS/18b.jpg
100% MoI 3D except the blinds (mograph)
Still have a lot of work to do on it...
5955.8 In reply to 5955.7
Hi DesuDeus, Google does index most of the content of the forum here, just so you know.
Your project is looking great!
It's just the "skin" or the internal apartments are made too ?
5955.10
@Michael yep I know but it's ok it's not top secret stuff, thanks by the way :) It's really cool to work with MoI on this, will do a topic when finished !
@Pilou I made fake walls for the internals so it's not empty and you got shadows on walls coming from the windows opening on different camera angles.
5955.11
I made a separate thread in case you're interested !
http://moi3d.com/forum/index.php?webtag=MOI&msg=5995.1
Show messages: All  1-4  5-11
