Repeat option in Offset
All  1  2-4
5954.2 In reply to 5954.1
Use one time the Offset function on a circle
Select "by distance"
Left click
Left click
So for the others circle (or any figures)
Select your Circle (or any figures)
Right click
move mouse
Left click
Left click
Right click
etc...
EDITED: 12 Jun 2013 by PILOU
5954.3 In reply to 5954.1
Hi Colin - things that involve object selection are kind of different form drawing commands like line and polyline, because of the additional selection step involved.
The way that repeat is really set to work with offset is when you want to generate multiple offsets all of just one same original base curve. You can select the curve, run offset, and then click the "Repeat" checkbox, and after you place each offset the offset command will automatically restart and let you immediately place another point to create a new offset with each click, until you do a cancel.
If you need to change the selection and make offsets on different curves instead of all on one same curve, then you won't be able to use the "Repeat" checkbox to help with that, but you can still use the right-click to repeat the last command to help out though. Get your selection set up and then right-click when you want to do a new offset.
> Having created the Offset, if I then click the Cancel button (while Repeat still ticked) the
> Offset function closes & I need to reopen it again??
Yes, that's how the repeat checkbox is set up to work - it will automatically re-launch the command until you either uncheck repeat and finish the current command or you hit cancel.
5954.4
Hi Pilou & Michael,
Thanks for the clarification.
regards Colin
Show messages: All  1  2-4
