deselect objects with certain name
All  1-9  10-15
5950.10 In reply to 5950.9
Yes I understood and you make it good, software have to have only one hiding system to not confuse user.
Last couple of days I'm learning Rhino, by this tutorial http://www.infiniteskills.com/training/learning-rhino-5.html and just finished this tutorial
Learned a lot of stuff.. Have to note I never know about curve from two points command and was very proud to find it in MOI (isect command).
I have to say you make GREATE job simplifying Rhino and grouping commands bravo!!!. I can not work in rhino after MOI because it too slow I mean a lot of commands it has and it takes a lot of time go through all that menus or typing. And great thing about moi is Boolean with curves! Super cool! And selecting ages and faces directly.
As I said you maid great JOB! Rhino is very powerful but it makes it very hulking.
5950.11 In reply to 5950.10
One thing I'd like to see in Moi is Blend command with the same functionality as in Rhino.
5950.12 In reply to 5950.10
Hi mir4ea, thanks, I'm glad that you like the simplification work that's been done for MoI!
I'm really familiar with the ways that things can be awkward in Rhino, since I'm the one that started Rhino many of the issues in it are my fault to begin with and early on with MoI I really focused on improvements in some fundamental areas, especially snapping and selection.
And yeah the sort of overall "structural philosophy" is very different between Rhino and MoI - in Rhino I tried to make each individual command to be more narrowly focused on a specific thing and more simple itself, which does lead to a certain kind of simplicity at the individual command level but the end result is a huge number of different commands which becomes difficult to manage in various ways, just too much stuff to sort through at too high a level in the UI. In MoI I've got a big focus on instead having a smaller number of more powerful individual commands that do different things depending on what is selected. There is kind of a tradeoff with this because it means some things are more hidden initially but that also gives a kind of more natural ramp up path where you can get more things done with the same UI as you get more advanced and familiar with things.
It was also a big priority to have a more modern type of UI that had real dialog controls for options rather than a totally text-oriented command line type UI like Rhino has, which is really unfamiliar to a lot of people these days. The command-line type interface can also be a real hindrance in certain ways because it only allows for sort of one input field at any time, like in MoI when you're drawing a rectangle you have both a "width" and a "height" field showing at the same time both of which update while your drawing.
The Rhino UI is based on AutoCAD and does work really well for people who have an extensive AutoCAD background. It's pretty weird for people who have never used AutoCAD before though.
5950.13 In reply to 5950.11
It's still on my target list for v3.
5950.14 In reply to 5950.12
<< many of the issues in it are my fault
You were very young at this date! :)
5950.15 In reply to 5950.14
<<You were very young at this date!
...mistakes of youth....but now we can say he's grown up very well ! :-)
Show messages: All  1-9  10-15
