Render to Clipboard (Linework)
All  1-2  3-6
5927.3 In reply to 5927.1
Here is a script that Ambimind made to help him get a line result. It works pretty good:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1049.33
I think you can fool with the lineweight numbers to get different results.
5927.4
Sorry! Very stupid of me. I have been using MOI3d with a huge list of shortcuts given to me by work and forget that they don't come preset. Oops!
The script we use to create the outline view is,
moi.view.shadeMode = (moi.view.shadeMode == 'HiddenLineWireframe' ? 'Shaded' : 'HiddenLineWireframe');
However, using this script along side it would be very useful.
var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 0.5; moi.view.shadeMode = 'Shaded'; v.renderToClipboard(3000,2000 ); moi.view.lineWidth = 0.5; moi.view.shadeMode = 'Shaded'; }
At the moment if activated when the first script is running, it disables it and screenshots the shaded view again.
Many thanks for the quick response once again Michael.
Cheers,
David.
5927.5 In reply to 5927.4
Hi David, thanks for posting the scripts! So the problem is that particular screenshot script is specifically setting the shading mode to plain shaded. If that part is removed then it should function like you want. The parts that need to be removed are the pieces that say: moi.view.shadeMode = 'Shaded';
So you would want to have your screenshot script be like this instead:
script: /* Generate hi res screenshot to clipboard */ var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 0.5; v.renderToClipboard(3000,2000 ); moi.view.lineWidth = 0.5; }
If you use this version instead, I think it should behave how you want, please let me know if it still does not.
5927.6 In reply to 5927.5
Amazing!
Thank you very much!
David.
Show messages: All  1-2  3-6
