boundare edges scripts
 1-14  15-34  35-39
Message 5922.15 deleted 30 May 2013 by ANDREI SAMARDAC
5922.16 In reply to 5922.14
Thank you!
5922.17 In reply to 5922.16
Michael, this script works very well! It works with joined surface or solids. It will be greate if it works with surfaces too. A this time I have 2 scripts SelectOuterLoopsAndDelete that work with surface and SelectOuterLoopsAndDelete2 that work with joined surface and solids. Could you make pleas SelectOuterLoopsAndDelete2 to work with surfaces too? If selected more than 1 surface it have to run trim if only one than just delete outer loops. It would be good to have one universal script.
EDITED: 30 May 2013 by ANDREI SAMARDAC
5922.18 In reply to 5922.17
Hi mir4ea, actually the #2 version should also be working with surfaces as well, it does the same thing, removes the outer loop and starts the trim command. Do you mean you do not want it to start the trim command if just one surface was selected? What if multiple surfaces were selected or a mixture of some surfaces and some joined surfaces or solids ?
Or is there some particular surface that is not getting untrimmed as you were expecting?
5922.19 In reply to 5922.18
Michael it dos not work with surfaces at all.
And yes it will be greate to have trimm off when only one surface selected.
5922.20 In reply to 5922.19
Hi mir4ea, it's working ok with surfaces for me over here. Can you please post a surface that is not working for you?
One thing to note is that if the outer boundary of the surface is already the natural boundary of the "underlying surface" then you won't see anything happen during the untrim, it's only when the outer boundary actually has cut away some material from the underlying surface that you will see anything happen.
You can get an idea of what the underlying surface looks like by turning on the surface control points.
5922.21 In reply to 5922.20
This one for example
5922.22 In reply to 5922.21
Just sturts trim command but outer loops are not deleted
5922.23 In reply to 5922.21
Hi mir4ea, the one you posted works fine for me over here... Are you sure you're selecting it before triggering the command?
Are you possibly selecting it in some special way like using the scene browser to select "Face" sub-objects instead of selecting it by just clicking on it?
5922.24 In reply to 5922.22
That's what will happen if it's not selected before you trigger the command.
5922.25 In reply to 5922.23
I selected it by clicking on it, run script nothing happen and trim command runs. May be it's because I'm using here trial version v2?
5922.26 In reply to 5922.25
Hi mir4ea, yes you need v3 for this script to run properly, it uses some things that are only in v3.
5922.27 In reply to 5922.26
aa good. I'm not at home just downloaded v2. Could you pleas make this script to tourn off trim when only one edge selected?
5922.28 In reply to 5922.27
Here's a version that does not run trim if there was only a single surface selected.
5922.29 In reply to 5922.28
Thanx!
5922.30 In reply to 5922.27
Also one thing to note about trimming - if the thing has all surfaces that overlap past each other so that there is a closed volume on the interior of it all, you can clean up something like that by using Construct > Boolean > Merge - if a bunch of surfaces are sent to boolean merge and there is one volume inside their intersections it will extract that volume and trim away all the excess outer surface pieces.
5922.31 In reply to 5922.30
Michael could you pleas modify a bit script by adding ShrinkTrimmedSrf command after separate.
I'll test it in work too see if it's good idea.
5922.32 In reply to 5922.31
Or as I can see this command works on solids too, not only on separated surfaces.
5922.33 In reply to 5922.31
Hi mir4ea,
It's not going to work well for this particular case where you're trying to reconstruct the original shape, because after the ShrinkTrimmedSrf things like planes will not get extended when their outer boundaries are removed.
You can see what the effect would be by just running ShrinkTrimmedSrf on your selection before running the script command - if you run ShrinkTrimmedSrf on a filleted box for example all surfaces will be shrunk down exactly to their current boundaries and so removing the outer boundary won't extend the shape unlike what you're seeing now.
I mentioned ShrinkTrimmedSrf previously not because it was something to use for this kind of untrim operation, but just because it's related to the general topic of how trimmed surfaces work. It's almost sort of the opposite of what you're trying to do here though.
5922.34 In reply to 5922.32
Yes ShrinkTrimmedSrf works ok on solids or joined surfaces also, not only on individual surfaces.
Show messages:  1-14  15-34  35-39
