Hi mir4ea, actually the #2 version should also be working with surfaces as well, it does the same thing, removes the outer loop and starts the trim command. Do you mean you do not want it to start the trim command if just one surface was selected? What if multiple surfaces were selected or a mixture of some surfaces and some joined surfaces or solids ?
Or is there some particular surface that is not getting untrimmed as you were expecting?
