join
All  1  2-3
5916.2 In reply to 5916.1
Hi mir4ea - you've got one surface duplicated on top of itself there. If you delete the duplicate you can then do a select all and do the join.
It doesn't work to join 2 surfaces that are stacked up directly on top of each other, the joiner then tries to glue stuff between those 2 surfaces along with the rest of them.
To delete the duplicate, click on each surface you can see and then do an invert selection and then delete. The duplicate is one of the longer side wall ones, the one on the right-hand side of the object after you open the file you posted.
5916.3 In reply to 5916.2
Thank you, I meat this problem sometimes, but have no idea how to solve it, thanx
Show messages: All  1  2-3
