Splitting Problem
All  1-5  6-8
5912.6 In reply to 5912.2
A couple of areas were a little off center from some previous operations:
That slight misalignment has created some little slivery areas, like here's a fragment of one little shelf like surface that sticks out a little bit off center on both sides:
The spot where that little slivery shelf crosses over from one side to the other at the top and bottom probably ends up as self-intersecting geometry and will confuse volumetric calculations.
You probably will need to reconstruct this object to avoid these little fragment areas, it may be best to revolve the whole thing from one profile.
5912.7 In reply to 5912.5
Let me know if you still need help - you can also get some construction curves by drawing in a plane through it and using Construct > Curve> Isect to generate intersection curves and then use those as a basis for preparing the revolve profile. There are some areas that need to be cleaned up before doing the revolve, zoom in to the juncture areas and you'll see some little fragmented areas in the intersection result coming from those little shelf pieces, you'll need to tune up those spots before doing the revolve.
5912.8 In reply to 5912.7
Micahel,
Thank you very much for your help. The Construct > Curve> Isect worked like a dream and I just had to pull some points around to get it sorted. It is amazing how tiny little errors can cause a problem but I guess with such brilliant tools available there is no excuse for being inaccurate.
Kind regards,
Philip
Show messages: All  1-5  6-8
