Functions that could come in handy
All  1  2-6
5902.2 In reply to 5902.1
Hi PL - thanks for the feedback!
re: 2D printing
Probably this won't be happening in the v3 time frame. I would like to have it in the future but it will probably be a while.
re: - Smoother Support for 3D Connexion Human Manipulating Interfaces
Over here the 3D Connexion device does work smoothly, are you having a problem with it on your particular machine? Do you still see any problem with the most current v3 beta release?
re: - Free Sketching function
There is a brush stoke type sketch function currently available under Draw curve > Freeform > Sketch.
re: - Better Support for Wacom Cintiq 24HD
Doesn't the Cintiq work just as a regular monitor and drawing tablet? It should work with MoI already, I guess I'll need to know more details about what kind of specific support you're missing here...
5902.3 In reply to 5902.2
I have one and, yes, that's how it works. All the buttons are programmable so I'm not sure what he's looking for there but I'm curious to hear!
5902.4
1) That's great that you are plannig a 2D printing function. Something simple should do it. Just to print what is on the screen.
2) The 3D connexion space pilot works but sometimes the movements get stuck and I have to go back using the mouse. It's not a big deal. Then it would works again until the same event occurs. I'm using Windows 8 64bit and MOI 2.0 that comes with Geomagic 2103. My driver is up to date.
3) I noticed the sketching function but it's not exactely a free Hand sketching tool since it somehow interprets a line as a polynome or similar. What I mean is something like skechbook pro has. A sketcher that you would use to do your first sketches. But maybe it's better to Keep MOI as efficient as possible whitout implementinig too much stuff. Actually that's what I really like about it. And, that keeps the speed up!
4) Please disregard my post about the Cintiq. It actually works very well. I shoud have asked you if Cintiq was intentionally implemented in MOI. I guess the aswer is yes.
Anyway, congratulation on the application. I'm shocked how powerful and fast that this masterpeace is! And beleave me, I can compare it. I have been using Catia V5 and other software for shape design that is definately les user friendly, much slower and bogus.
Is there another MOI Version (>2.0) coming with Geomagic 2013 soon?
Kind regards
PL
5902.5 In reply to 5902.4
Hi PL,
I think that Geomagic/Alibre has some pretty good printing support, so for the time being you should be able to bring your geometry into there for doing the printing.
I'm not sure when the printing will be implemented directly in MoI, it may be a while.
Hmm, I wonder if your device is actually getting physically stuck somehow. You might try using the "Calibrate" function in the 3D connexion control panel thingy.
You might also try using the most current MoI 3.0 beta which you can get from here: http://moi3d.com/beta.htm
If it's a problem with the hardware sensor actually getting stuck in some position then there probably isn't much that MoI itself would be able to do about that.
I would love to do an integrated image based sketch package, but there would be a tremendous amount of work involved in doing that, it's not really a feasible area for me to tackle.
If SketchBook Pro has the kind of behavior you need, then I'd recommend doing your sketch inside of SketchBook Pro and then bring your finished image into MoI as a background image, the tool for bringing in images into MoI is under View > Image:
http://moi3d.com/2.0/docs/moi_command_reference5.htm#image
There's nothing really specifically targeting the Cintiq, but just in general MoI has been created to be friendly for use with a drawing tablet and that general tablet friendly UI design should apply well to the Cintiq also. If you have the largest one you may want to increase the UI size in MoI to make the buttons and text a little larger, there is a slider for that under Options > General > UI size.
Thanks, I'm glad that you like it!
I'll be coming out with MoI v3 sometime this year but there are not currently any plans in place for how that will be incorporated with the Geomagic/Alibre bundle deal. Probably you'll be able to purchase a discounted v3 upgrade version for getting MoI v3.
5902.6 In reply to 5902.5
Great News. I will definately give MOI 3.0 beta a try.
Thanks for your time!
Respectfully
PL
Show messages: All  1  2-6
