Exporting to Cut2d
All  1-6  7-12
5888.7 In reply to 5888.5
I have attached a sample MoI file that I'd like to cut out. The number of options in CamBam makes it look very unfriendly. If you can walk me through it in a video, I'd certainly be interested in giving it a try.
Thanks!
5888.8 In reply to 5888.7
Alligator.
Would you intend to cut those parts from sheet material such as plywood or MDF etc? If that is the case, then you would need to be working from curves out of MoI, rather than solids. So assuming that to be true, I've extracted some curves from your model and exported them to CamBam as a dxf file and my video shows a little of what can be done in this way.
Notice how you create features such as pockets at different Z levels, by making alterations to the Stock Surface and Target Depth settings, without the need for anything other than a 2D drawing in Plan View. CamBam can also use stl output from MoI to machine direct from the solid, but it wouldn't really be an appropriate machining strategy for the kind of model you have posted here.
I hope you can see that it's not too difficult to get going in CamBam now and let me know if you need more help or information.
http://screencast.com/t/kyunFyUODc
Martin (2).
EDITED: 15 May 2013 by BLOWLAMP
5888.9 In reply to 5888.8
Thanks, that was actually very helpful. I appreciate the time you took to make it, I might give CamBam another try. I was planning to cut these parts out of maple.
It appears that CamBam gives you a lot more choices than other CAM packages out there. However, one of the problems I've been having is the round edges on the top of my parts. They were easy to make in MoI, but have proven difficult for a beginner to machine. Your tutorial exports the shapes as 2D drawings, which is something I've never done before, but seems to simplify cutting 2D parts. Only in this case, I'm trying to cut 2.5D parts for at least one of the two pieces. So I'd have to modify things somewhat to round those edges.
5888.10 In reply to 5888.9
The easiest way to round those edges is with a form tool, but if you don't have one of those, then CamBam has this feature http://www.cambam.info/doc/plus/cam/SideProfiles.htm which works on any shape of boundary and seems to do exactly what you're asking for with the rounded edges of your model.
Martin (2).
5888.11
In the video shown above, the Browser button is used to select only the projection of the parts onto the X-Y plane. When I try that with MoI, I don't have the same options shown. For example, my "Curves" and "Surfaces" are grayed out. I can't seem to get just the 2D view of the parts. I'd like to do this because I have some edges with a fillet that I'd like to remove or undo.
Can you explain how this was done?
5888.12 In reply to 5888.11
Hi Alligator, if your "curves" and "surfaces" section of the scene browser are grayed out, it means you don't have any curve or non-solid surface objects currently in your model. All the things that look like curves that you are seeing are not "standalone curves" but instead are edges of solids.
You can convert edges into regular curves that are not connected to a solid by selecting the edges and using copy and then paste to duplicate them. Then you can hide the solid and you'll be left with a bunch of curve objects. You can also use Construct > Curve > Silhouette to generate silhouette curves for things like the outline border of a sphere where there is not necessarily an already existing edge.
But one thing to keep in mind is that you'll easily get a bunch of duplicated curves if you are duplicating edge curves on some shape that has both top and bottom faces on it. Like for instance if you have a cube if you duplicate all edges you'll have 2 sets of edges in the top view and if you export that to AI format they will get projected on top of each other and you'll have duplicates. So probably you'll want to delete the upper part of your model and only export the bottom faces if you have something like an extrusion with similar top and bottom faces in it.
In the future I want to make a mechanism for generating a "hidden edge" type display when exporting to a 2D format like AI, but currently it doesn't do that and just all edges or curves get exported so you need to yourself remove any edges (probably by just removing all the faces of the object other than the bottomost one) that you don't want to be part of the export.
That's a pretty different process - it is possible to remove edges but you need to first separate out the surfaces in that area so the edges you want to remove are not attached between 2 surfaces, then you can select the entire boundary and hit Delete to do an "untrim" and remove that boundary and recover the underlying surface there. See here for an example: http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
And there's a longer tutorial on these kinds of object repair techniques here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
Show messages: All  1-6  7-12
