remove internal parts?
All  1-5  6-7
5856.6 In reply to 5856.5
5856.7 In reply to 5856.1
Hi Paul, there is no function for automatically removing internal parts. The closest thing is probably the select visible objects script that Marco links to above - when triggered that will select objects that have some pixels being displayed in any view. It will select all objects that could have possibly been targeted by a click right then. If you rotate around a bit in the 3D view and trigger that several times it should get all the outer objects selected.
Once you have all the outer objects selected, you can use File > Export to write just those selected objects out, or also do a Select > Invert and then delete the interior ones.
Also see here for some general tips on reducing memory load for mesh export:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5322.2
Show messages: All  1-5  6-7
