Also maybe I'll add in a "Delete input objects" option as well, since if you're projecting something that's only a little distance off from planar it can be difficult to visually see the difference between the original and the just projected one.
So that could work like this:
Then if you push "Use CPlane" button, it would use the Top, Front, or Right sides (set by the dropdown next to it) of the current cplane as the projection direction and finish right away.
