Is there a way to "convert selections"?
All  1-2  3-6
5813.3 In reply to 5813.1
There are several edge scripts on Petr's website, under MoI help button...
5813.4 In reply to 5813.2
Thank you. But the solution I'm looking for would allow me to select a face then immediately convert that selection to just the "edges" of that face. So that I could (for instance) add fillets.
The "Types" tab in the Browser seems to only work globally. It doesn't actively change the selection type, of an already selected surface/curve/face etc. Again, I'm referencing the selection options in Cinema 4D.
5813.5 In reply to 5813.4
Hi sneather, on Petr's script collection page that bemfarmer mentions above, there is a script that will convert a face selection into an edge selection of all its surrounding edges.
It's this one here:
http://kyticka.webzdarma.cz/3d/moi/#SwitchSelectionFromFaceToEdges
Set up that script on a shortcut key (paste the whole script in as the "command" part of the shortcut key) and then when you trigger that key you should get the selection behavior that you are asking about.
But one note - you mentioned doing this so that you could add fillets as one example, but fillets actually understand a face selection already - if you have faces selected and then do a fillet all the edges belonging to those faces will be targeted for filleting. So if you want to do filleting there is no need to do this selection switching as another extra step, just run fillet directly after you have done your face selection.
5813.6 In reply to 5813.5
Thank you. And yes, I do know that I can fillet based on face selections, too.
However, being that adding fillets (in any program) is an imperfect science, to say the least, I have found that sometimes I need to be extremely creative with my selection process, and order of chamfering. It all depends on just how complex the product CAD is.
Show messages: All  1-2  3-6
