Co-planar alignment ?
All  1-6  7-10
5808.7 In reply to 5808.6
The first link you gave pointed to my own discussion with my actual I/O SU Unfold tool solution O:-)
Unfortunately this works not very well because it is not precise enough for what I have to do : aligned meshes in SU with the Unfold Tool (or the 2 other SU unfold plug-ins) are not exactly matching the same plan. This could work for many folks as it is just few parts of millimeter only, but enough to ruin my aim.
But of course if it is too much coding work I understand you don't want to do what I suggested.
Yes, as you tell it Form-Z seems to do the unfolding job.
As I understand your words, MoI will never deal with meshes nor any unfolding process, so for this use I will investigate further in 3D modelers world to find my needed tools.
-- EDITION -
Well, in fact the best fit for my needs is a combination of MoI with SU as the work flow I have reported already :
1 modeling within MoI
2 exporting in SKP (meshes) file format
3 using "Unfold Tool" SU plug-in to unfold the surfaces needed for the plan
4 Exporting DXF with "Export DXF/STL" SU plug-in
5 opening this DXF within MoI to clean and make a cool planar drawing well fitted.
Best Regards,
Guy
EDITED: 4 Apr 2013 by ALOMPHEGA
5808.8 In reply to 5808.7
Hi Guy,
Yes, that's correct. ... Well, I'm not sure about "never" but at least not for quite some time. Functions that involve editing or processing polygon mesh data (other than for export) are not currently a focus for MoI, MoI is focused on working with NURBS data.
5808.9 In reply to 5808.8
Yes, understood, but "workarounding" please read my edited message above ;-)
My best,
Guy
_____________________________________________________________________________________
always working on few funny projects : www.nauticaerium.com ; www.conceptarum.com and so on...
5808.10 In reply to 5808.9
Hi Guy, that's great that you have a sequence that will work for you!
Show messages: All  1-6  7-10
