How do you view normals?
5804.1
Hi, how do you view the direction of normals on a plane?
I mostly model for 3D printing, and right now I export STL, open in NetFabb, and then flip normals back in MoI. Any ideas how to view normals in MoI so I can skip NetFabb?
Thanks!
Nancy
5804.2 In reply to 5804.1
Hi Nancy,
There's no way yet to view surface-normal orientation in Moi yet as Michael may explain.
however, You can use the picker activated by the 'C-Plane' tool in the 'View' tab: the picker will show you the (u,v,)W-orientation of the surface.
So don't click on 'Done', but just touch the picker to any surface.
If the picker appears to sink below the surface, then you'll need to use the 'Flip' text command.
By the way, as you know, the 'Flip' command works on the entire compound surface, so if one sub-surface has an incorrect orientation, then you would have to Separate that surface, flip it's normal, then re-Join it to its compound group.
Mike
EDITED: 2 Apr 2013 by MAJIKMIKE
5804.3 In reply to 5804.1
Hi Nancy, there is not really any regular normals viewing mechanism set up in MoI.
Usually that is not something that you need to worry about with 3D printing, because once you form a completely closed solid, the normals will automatically get oriented to point towards the outside of the volume.
STL files are typically meant to contain closed solids in them... So usually as part of the process of generating an STL file you should be creating a completely closed object before doing the export, and once you do that the normals should get automatically oriented.
So for example instead of making just an infinitely thin plane to export to STL instead make a thin solid box.
5804.4 In reply to 5804.3
Thanks for the quick response. Super helpful!
Nancy
