Would a simple image capture be a wild goose chase? I like to model, then print out a screenshot and sketch over the top. But a screenshots resolution is not enough sometimes?
Hi yakas, it is possible to set up a script on a shortcut key that will generate a viewport image but at a higher resolution than the actual current screen. It places the image into the clipboard so you can then paste it into an image processing program.
Hi yakas, also have you modified the script to make a particularly large resolution image? If so it may be larger than what the video card supports, try lowering it somewhat.
