Question for Michael
All  1-2  3-11
5799.3
Good questions beanworks, turned out to be an enjoyable interview.
Thanks to both you and Michael.
5799.4
FEA and rendering with MoI,
I like it !
Thank you for the questions
Kaël
5799.5 In reply to 5799.4
Would a simple image capture be a wild goose chase? I like to model, then print out a screenshot and sketch over the top. But a screenshots resolution is not enough sometimes?
5799.6 In reply to 5799.5
Hi yakas, it is possible to set up a script on a shortcut key that will generate a viewport image but at a higher resolution than the actual current screen. It places the image into the clipboard so you can then paste it into an image processing program.
See here for the script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1049.5
That should do what you are looking for.
5799.7 In reply to 5799.6
great, thanks
5799.8 In reply to 5799.7
Hi set up the script but when i paste the capture into photoshop the image is black?
Any Ideas
5799.9 In reply to 5799.8
Hi yakas which MoI version and which operating system are you using?
5799.10 In reply to 5799.8
Hi yakas, also have you modified the script to make a particularly large resolution image? If so it may be larger than what the video card supports, try lowering it somewhat.
5799.11 In reply to 5799.10
Works now, I updated my driver. thanks
Show messages: All  1-2  3-11
