2 Spheres - modify lines after boolean operation
All  1-2  3-5
5796.3 In reply to 5796.1
You cant really modify the "edges" of a surfaces in that way. You "CAN" work on modifying the surface itself, and also note that when you generate surfaces from curves, they will have a history that updates with the curves. Here is a sample where I seperate out the surface created from the boolean, then do some further work on it.
5796.4 In reply to 5796.1
Hi Mark, no you can't just grab any surface that's part of solid and scale it, you would just need to reconstruct that object with your original sphere scaled down and repeat the same steps you did to build it in the first place.
In the future I do want to make a deeper history function that would allow for the kind of editing that you're asking about but mostly MoI is focused on making things as easy and quick as possible to just do the initial drawing.
There are other CAD programs that are focused on that kind of history, like SolidWorks and Alibre, if you need to have a deep history function you can use one of those other programs to get that kind of functionality rather than MoI - the tradeoff is that they are not as easy to use and don't have the same kind of fast and fluid initial drawing that MoI has.
5796.5 In reply to 5796.4
thanks very much for that video and your time - this is wonderful. Can keep on working now.
Best regards
Mark
Show messages: All  1-2  3-5
