Need help !
 1-16  17-29
5795.17
yes that is the way those type of file are. basically a mess. You work with what you get.
If need be I can spit out a 3D model of the terrain but it will be a mesh not a nurb.
Val
http://www.suburbanartworks.com/
5795.18
I use FormZ, for this kind of project, it's the good choice
5795.19
I noticed that the terrain is really subtle, I'm trying to obtain a polygon file right now.
But the good thing if I can have a terrain inside MoI3D is that I can project the roads on it :)
I imported the lines in MoI 3D already, thanks for converting them for me !
Regards,
Sam
shapenoid.com stojan-voumard.com
5795.20 In reply to 5795.19
""""""""""I noticed that the terrain is really subtle,"""""""""""""
Thats kindof what I've been struggling with. There really isnt that much elevation in that small area. Here's a file with 1.5 arc elevation data for that part of Geneva. It's not based off of your curve data, but DEM data. I've converted it to a nurbs surface, so you can scale the z value to "exaggerate" it a bit for visual effect if that helps. I also put a topo image in it to give some reference to the surface/location.
The scale is a bit too small for what I was thinking. Maybe one of the form-z guys can make a terrain out of the actual contours in the file.
I am also fooling around with embossing topo or map data onto this surface, which may turn out to be something usable for buildings and such to be placed. I'll let you know if I get anything worth showing.
EDITED: 27 Nov 2020 by BURRMAN
5795.21 In reply to 5795.20
Thanks Burrman, I know Geneva is kinda flat (live there) but there's a lot of streets that have some slope.
The problem is when you look at the cutaway is that there's two main entrances at two different levels (number 1 and number 2)
Also there's some streets at number 3 that are on a different level than streets at number 4
https://dl.dropbox.com/u/44982094/Capture%20d%E2%80%99%C3%A9cran%202013-03-28%20%C3%A0%2009.42.43.PNG
So I can't really make everything "flat" it need some kind of level difference.
I'm calling a guy to get topology in polygons then I guess I'll just adjust it to fit the buildings inside of Cinema 4D.
Thanks for your help :)
5795.22 In reply to 5795.21
I recently did a project with some simple topo needed in a track/road like situation. Although not quite as complex as your roads, it may be worth a look. (Kindof hard to see but the go Kart track is going up and down and banking in the corners and such)
Really if all you need are some subtle changes for a couple areas, especially with roads that can be defined, Maybe just make a grid surface that you can trim the roads out of, then lower and blend them. The grid surface can be raised and lowered in some key areas with point pulling to create some levels.
2 cents.
5795.23
So apparently they don't have polygonal data for the ground...
Will have to do it by hand in C4D sculpting :D
5795.24 In reply to 5795.23
...there is a Google Earth to C4D plugin available, quite reasonable priced..
http://www.archiplug.com/EN/GETerrain.aspx
Maperative is a free solution based on OpenStreetsMap
http://maperitive.net/
provides 3Dexport to .cae (Collada)
3dm wise..there is a rhinoplug
http://www.rhinoterrain.com/
imports all sorts of things..DEM, Pointclouds, Google Earth..but really a bit of an overkill for just 1 or 2 projects..
5795.25 In reply to 5795.23
I'de be glad to put this up as an obj for you to review. Not sure how close I got the topo map to the terrain data, but it looks close. Converting it to NURBS was not going well, but maybe it will suit the poly need?
Let me know.
5795.26
Hi everyone,
Thanks for all the help ! I finished the trainstation model today and now I'm starting to build the stuff around
Is anyone kind enough to convert those to .3DM ? I only need the curves and the buildings, I will open them in rhino and generate the terrain with the patch tool (maybe before I'll clean all the lines)
Then I will manually place the buildings on the ground :D Fun part (could do it with grasshopper)
I found a video tutorial about the patch tool it seems to work great if curves are clean and if you first do an extract points.
https://dl.dropbox.com/u/44982094/CEVA_EAUX_VIVE_DXF_MULTIFACES.dxf.zip
https://dl.dropbox.com/u/44982094/CEVA_CHENE_DXF_MULTIFACES.dxf.zip
https://dl.dropbox.com/u/44982094/CEVA_BACHET_DXF_MULTIFACES.dxf.zip
Thank you :)
5795.27 In reply to 5795.26
Hi Desudeus, Rhino should be able to load the buildings from the DXF file - when I tried it looked like the buildings were made up of polygon data, which is why they don't come into MoI v3's new DXF reader, MoI's reader seemed to bring in the curves ok though.
But if you're already going to use Rhino for the patch terrain method, you should also be able to use it for importing that DXF file as well too.
5795.28
I think some confusion might be that the location of the drawing is so far away from 0,0,0. as I opened it in Moi and initially didn't see anything.
I had to look at it in Max first and find out that the location is 208679'6.5", 93074'4.75", 34' 8.5"
5795.29
Got the terrain made, buildings imported, I'm now projecting the streets onto the terrain :D
My computer is crying from the load... And it's a 12 core...
Show messages:  1-16  17-29
