OBJ material names by style
All  1-3  4
5790.4
Hallo Michael,
sorry for the delayed answer. Thank you very much for your help! I got it run now. :) Maybe someone like to use it too - attached the full MoI Convert script and the Rhino button script for renaming the imported OBJ meshes.
At the moment it stay one main problem, but I suppose so it can be solved by the Rhino team only - Layer names like "GrĂ¼n" are renamed to "Gr n". At the OBJ file the names are perfect, but after the import to Rhino the names are destroyed. I hope it can be fixed.
The script for bringing the meshes to the right layer is quite slow. Doe's anybody know how to get it faster? Is it because I packed it to a button script?
Best-
Micha
Here my Rhino button script:
_-import "d:\temp\#moi.obj" ImportOBJGroups=DoNotImportOBJGroups ImportOBJObjects=Yes IgnoreTextures=Yes MapOBJYToRhinoZ=No _enter
_QuadrangulateMesh _enter
_-RunScript (
Option Explicit
Call ObjToLayerByName
Sub ObjToLayerByName()
Dim arrObj, strObject, strName
arrObj = Rhino.GetObjects ("Select meshes", 32, , true)
If IsArray(arrObj) Then
For Each strObject In arrObj
strName = Rhino.ObjectName(strObject)
If InStr(strName, "[") > 0 Then
strName = Left(strName,InStr(strName, "[")-1)
End If
If Rhino.IsLayer(strName) Then
Rhino.ObjectLayer strObject, strName
Else
Rhino.AddLayer strName
End If
End If
End Sub
Visualisation for Designer and Architects | http://www.simulacrum.de
Show messages: All  1-3  4
