OBJ material names by style
All  1  2-4
5790.2 In reply to 5790.1
Hi Micha, in the just recently released Mar-17 v3 beta there is a new function you requested for exporting to OBJ using the style name as the group name in the OBJ file.
That should then allow you import into Rhino using the option in the OBJ importer to map group names to layers - won't that improve your export into Rhino?
Here's the relevant part of the release notes:
Updated OBJ export settings - added a new setting in moi.ini for OBJ export to help with mesh transfer into Rhino. [OBJ Export] WriteStylesAsGroups=n When this is enabled by changing to WriteStylesAsGroups=y then the style name will be written as the group identifier when generating the mesh. This allows for using the setting in Rhino's OBJ importer for importing groups as layers to get the mesh back to the same layer as the original object. Requested in the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5637.1
5790.3 In reply to 5790.1
Here is a function that you can add to the script that will change style names to replace spaces in any style names:
function RenameStylesWithSpaces()
    var styles = moi.geometryDatabase.getObjectStyles();
    for ( var i = 0; i < styles.length; ++i )
         var style = styles.item(i);
         style.name = style.name.replace( /\s/g, '§' );
Paste that into that into the top of the script. Then modify the script to call that function before calling AssignObjectNamesFromStyles, like this:
RenameStylesWithSpaces();
AssignObjectNamesFromStyles();
5790.4
Hallo Michael,
sorry for the delayed answer. Thank you very much for your help! I got it run now. :) Maybe someone like to use it too - attached the full MoI Convert script and the Rhino button script for renaming the imported OBJ meshes.
At the moment it stay one main problem, but I suppose so it can be solved by the Rhino team only - Layer names like "GrĂ¼n" are renamed to "Gr n". At the OBJ file the names are perfect, but after the import to Rhino the names are destroyed. I hope it can be fixed.
The script for bringing the meshes to the right layer is quite slow. Doe's anybody know how to get it faster? Is it because I packed it to a button script?
Best-
Micha
Here my Rhino button script:
_-import "d:\temp\#moi.obj" ImportOBJGroups=DoNotImportOBJGroups ImportOBJObjects=Yes IgnoreTextures=Yes MapOBJYToRhinoZ=No _enter
_QuadrangulateMesh _enter
_-RunScript (
Option Explicit
Call ObjToLayerByName
Sub ObjToLayerByName()
Dim arrObj, strObject, strName
arrObj = Rhino.GetObjects ("Select meshes", 32, , true)
If IsArray(arrObj) Then
For Each strObject In arrObj
strName = Rhino.ObjectName(strObject)
If InStr(strName, "[") > 0 Then
strName = Left(strName,InStr(strName, "[")-1)
End If
If Rhino.IsLayer(strName) Then
Rhino.ObjectLayer strObject, strName
Else
Rhino.AddLayer strName
End If
End If
End Sub
Visualisation for Designer and Architects | http://www.simulacrum.de
Show messages: All  1  2-4
