Objects vanishing out of file ...
All  1-3  4-5
5788.4 In reply to 5788.3
Hi Heiner,
> One more question: Is it possible to convert curves from a
> curve with edges into one smooth one with direct or indirect
> control points?
There is a Rebuild command that can help with that:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
If you set it in "# of points" mode and turn off "Keep corners" will sample points along the curve and build a new smooth curve through those sampled points.
Sometimes it can be good to just redraw a messy curve though just by snapping points onto the old one using the regular curve draw commands.
5788.5 In reply to 5788.4
Thanks a lot, thats a great help!
Heiner
Show messages: All  1-3  4-5
