Objects vanishing out of file ...
All  1-2  3-5
5788.3 In reply to 5788.2
unfortunatley I can not send any files, since i am here under a heavy "Non disclosure spell" ...:-(
But i will try to recreate the problem with another model which i can use more freely.
Your tip with the OBJ converter was worth a million, because it seems as if it not only solved my
vanishing objects problem but also my importing issue. Thank you a thousand times!
One more question: Is it possible to convert curves from a curve with edges into one smooth one
with direct or indirect control points?
Best regards,
Heiner
5788.4 In reply to 5788.3
Hi Heiner,
> curve with edges into one smooth one with direct or indirect
> control points?
There is a Rebuild command that can help with that:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
If you set it in "# of points" mode and turn off "Keep corners" will sample points along the curve and build a new smooth curve through those sampled points.
Sometimes it can be good to just redraw a messy curve though just by snapping points onto the old one using the regular curve draw commands.
5788.5 In reply to 5788.4
Thanks a lot, thats a great help!
Heiner
Show messages: All  1-2  3-5
