.3dm import in VectorWorks 2013
5781.1
... loads MoI 3D files without a problem!
that means I use MoI even more often at work. Superb!
(just wanted to express my happiness for this fact)
What you see is what you believe - so don't. (from an Amiga500 demo)
5781.2 In reply to 5781.1
This is great news! Is the 3DM import function brand new for version 2013 ?
5781.3 In reply to 5781.2
I never had the last version of VectorWorks, only the 2009version that couldn't handle .3dm.
Just last week I received the 2013 version that can handle Rhino .3dm files - and imports MoI without a hitch.
In the office we might have some 2011 or 2012 versions so I'll check there as well.
edit: just used the .3dm export - and it works as a treat. There were some difficulties with the .dxf import and saw the .3dm export from VectorWorks - and that finally worked.
for explanation with the .dxf problems:
I had a .dwg file using 3D splines as a way to show a terrain profile. exporting those to .dxf from acad and importing that file to MoI I always got all the profiles 2x - one as the profile and 1 projected in the top view to 1 level, but that level in the middle of the height of the terrain, so it was really hard to discern between the spline I want and the ones I don't.
In the end I imported the .dwg in VectorWorks and exported again to .3dm and it worked as I wanted it to be!
EDITED: 21 Mar 2013 by MACRAY
