Why does the chamfer aren't present in a N-gons export (.obj)
All  1-2  3-8
5776.3 In reply to 5776.2
Here is the .igs file and the .obj
This model is not very complex and I could redraw it in cienma 4D but anyway i am use to import model more complicated and in these case the Moi soft could be useful.
I have another question. With the Moi export in .obj i never get the good rendering withe a radial texture like in the original manufacture product.
The texture seems alway in bad orientation.
May be i am not very professional user but I never can have the good texture finish.
You can find the result (attachement) with the model redrawn in cinema 4D.
Many thanks
5776.4 In reply to 5776.3
Hi - first an answer to this other question:
Probably the radial texture uses the UV coordinates that are set up on the mesh. Although MoI does export UV texture coordinates they're really basic and you need to create your own UV mapping instead. There is probably some kind of "UV unwrap" method built into Cinema4D that will do that for you. I do want to generate better UV coordinates directly from MoI in the future but it hasn't been a priority so far because poly modeling programs all have their own UV generation mechanisms already.
5776.5 In reply to 5776.3
Hi - is the chamfers that you're talking about the ones highlighted in yellow shown here? :
If so then you're not seeing those in your render you show there because they're on the opposite side of the object from that point of view. Spin your camera around to the other side of the object to see them.
Let me know if that wasn't it.
Thanks, - Michael
5776.6 In reply to 5776.5
No, the chamfer I was looking for are on the opposite side
But. As i have said, the chamfers were visible on the wireframe view but not highlighted as yours.
Forgive me, I didn't take time today to see this problem.
Perhaps tomorrow
Anyway, many thanks for your help.
5776.7 In reply to 5776.6
Sometimes chamfers are difficult to see distinctly in shaded views when there is only a single light source. If that's the case try using a broader set of lights or maybe an environment map type lighting.
If you're still having problems can you show a screenshot that shows the problem? The screenshot that you showed previously was from the opposite side of the object from where the chamfers are at, so that was totally normal in that case that you would see them only in a wireframe view where you're seeing all the way through the object.
5776.8 In reply to 5776.6
Or did you maybe try to do the export before actually finishing the chamfers? Some commands like Chamfer or Fillet have a final stage in the command where you need to push "Done" or right-click in a viewport to finalize the command.
If you tried to export before actually finishing the command the chamfer will get canceled.
When I load your IGES file here I only see the chamfers on one side of the object as I showed highlighted in that previous screenshot, the opposite side of your IGES file looks exactly like your render screenshot, like this - no chamfers present on that other side:
So as far as I can tell the render that you showed looks the same as this, sorry if I am not understanding what you are getting at...
Maybe you thought you did a chamfer but did not finish the command ?
Show messages: All  1-2  3-8
