parametric quotes
All  1-11  12-13
5770.12 In reply to 5770.11
Hi Michael, you understood me with the distance constrainer ... Thought there might be problems with the right click storing values idea, but the amount of effort is no different from clicking the line tool or whatever to break the constraint as there is in having to retype it all the time, but if it's not an easy implementation thing then it's no real problem as copy and paste and array tools suffice nicely but thanks for giving it thought.
Martin Spencer-Ford
5770.13 In reply to 5770.12
Hi Martin, yeah right this moment it's not an easy thing to implement since the command repeat thing only repeats actual commands, setting the distance constraint is not quite the same kind of thing as an actual command.
Show messages: All  1-11  12-13
