simultaneous X and PERP snap line to curve?
 1-14  15-27
5767.15 In reply to 5767.14
No problem brash, I'm glad that does what you need! Sorry I did not understand what you were asking about at first.
Also, when using perp/perp snap the initial point on the first curve must be somewhere in the general area (like with 50 pixels or something like that) of where the actual final point will be at. That helps to avoid it being triggered accidentally all the time, basically it only triggers if there was a shared perpendicular line in the screen area nearby both the first and the second pick.
If you have placed the first point very close to where the final perp/perp snap will be, you will usually find the activating point on the second pick to be just slightly to one side or the other of the "single perp" snap. You will know when you have activated perp/perp since you will see the label switch to "perp/perp" and it will also show on both points to indicate that both the first point and the second point are being modified by this particular snap.
The "single perp" object snap is different since it snaps the current point only, finding the perpendicular line coming directly from the base point. Perp/perp only uses your picked points as guides for where to look on the curve and the actual perp/perp snap locations come from a calculation that finds a shared perpendicular line between the curves.
5767.16 In reply to 5767.15
Thanks again, Michael!
Pls note my logic as simple man as I showed in first pics ;) To draw helper line in need direction and relocate it to find perp to the helper line on curve. maybe possible add this function "perp locator"?
5767.17 In reply to 5767.16
Hi brash,
Maybe, but I'm not sure how it would work for just regular picks which in general only have a "previous point" defined for finding perpendiculars. Do you mean it would be added only specifically to the construction line relocation only? That's getting pretty highly specialized, and it might be tricky to give a good label to actually show what was happening there, I can't really just say "perp" because the regular "perp" snap does something different than that (using the direction from the previous point).
5767.18 In reply to 5767.17
I would solve his particular workflow desire with "Keep C-lines"....
On that note, Michael, has anything changed enough about what Paul's custom "construction Line" command does that it could be altered to include the c-line edit option on the kept lines?
So rememeber that the initial inaccessibility to the kept c-lines (or maybe the visual that they have been "activated or picked") yet still "transformed with the regular tools" (They do actually get picked like objects. with a name and a style). Maybe that can now be added to it?
EDITED: 14 Mar 2013 by BURRMAN
5767.19 In reply to 5767.18
Hi Burr,
But he's looking to find a location on a curve where the curve perpendicular matches a particular cline direction - that would be a new kind of snapping function (but one that can currently be done by perp/perp snap instead), just keeping clines doesn't give that.
No, not currently - right now it is built into that little pop up menu that it is implicitly editing (by things like reorient or relocate) the last created cline.
5767.20 In reply to 5767.19
I was editing my post while you were posting back.....
""""""""""But he's looking to find a location on a curve where the curve perpendicular matches a particular cline direction - that would be a new kind of snapping function (but one that can currently be done by perp/perp snap instead), just keeping clines doesn't give that.""""""""""""
Yeah, I saw that and was thinking of the perp/perp, but he seems to be wanting to do it kindof "backwards', and I thought that the keep c-lines would let him do it. It's kindof the same as drawing an actual "line first", then having that to work with.
5767.21 In reply to 5767.20
This is what I think he's trying to do.
5767.22 In reply to 5767.21
Hi Burr, I don't think that's quite it - from what I could tell he's looking for something like "draw a cline", then move that cline onto a curve snapping it to the particular point on the curve where the curve perpendicular has the same direction as that cline.
You can currently get that "point on the curve that has a specific perpendicular" by doing perp/perp snap currently like this:
He was originally trying to get that same point shown here with perp/perp snap by drawing in a y-axis direction construction line rather than an x-axis direction construction line like you see in the screencap here.
This problem of "find the point on a curve that has a specific perpendicular direction" cannot be solved by just doing a rotation of a construction line - it involves some kind of snap function that will seek through the curve finding the right spot on the curve that has the curve tangent or curve perpendicular going in that particular direction.
5767.23 In reply to 5767.22
""""""""""find the point on a curve that has a specific perpendicular direction" cannot be solved by just doing a rotation of a construction line - it involves some kind of snap function that will seek through the curve finding the right spot on the curve that has the curve tangent or curve perpendicular going in that particular direction.""""""""""
Yes, the rotation was just an example of using the kept cline as an object. It seemed the question was "moving an existing cline from somewhere else" perp to perp on a curve somewhere else, which can be solved by the keep c-line/object transform thing I showed. I was just pushing to see if I could get the keep c-line beefed up, because what you are showing is "just make a new c-line" which works fine.
Kindof like asking to have the BoundingBox command have an axis directional method added. I think that kind of tinkering just needs to wait, because it can be acheived by rotating the part, instead of making the command do the rotation.
Don't work out of this validity aera! ?
5767.25 In reply to 5767.24
Hi Pilou, yes that's normal and intentional - the perp/perp snap will only engage if the initial pick point was within 65 pixels (actually 4 times the object snap radius) of the actual perp/perp location.
That helps to keep perp/perp to only engage when you pick somewhere in the general area of the perpendicular line, otherwise it was kind of weird when the base point would suddenly fly off to some far away location from your picks.
5767.26 In reply to 5767.17
When I do Relocate cline I see on object "On", "Int", "Cen", "End" etc. and intuitively expect "Perp/On" and "Tan/On".
5767.27 In reply to 5767.26
Hi Brash, the "On" osnap is so generic it is intentionally not combined with other object snap labels if a "specific point" one is active.
That's because otherwise you would be seeing it added to every single label except "Cen", because they are all points on the curve.
So since that would be a lot of extra labeling that would be nearly always present, "On" is only displayed when there is not any more specific snap engaged.
Show messages:  1-14  15-27
