Construction line snap plane feature...missing on osx v3 beta
5755.1
I can't seem to make it work..
Is it supposed to be in the current v3 beta or a future addition?
EDITED: 6 Mar 2013 by NICKP100
5755.2 In reply to 5755.1
Are you refering to the ConstructionLine3 script?
5755.3 In reply to 5755.2
Im referring to the feature that Michael has incorporated in the V3 notes:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4665.3
5755.4 In reply to 5755.3
Just tried this feature, which I had missed learning about.
This feature is working for me, with the November 6, 2012 beta.
(Created two clines with the shortcut script, from one centerpoint. Feature works for commands involving this centerpoint, e.g. rectangle, circle, line.)
5755.5
Unless I'm doing something wrong it is apparently missing on the latest v3 osx beta...
5755.6 In reply to 5755.5
""""""""Unless I'm doing something wrong it is apparently missing on the latest v3 osx beta...""""""""""
Be sure to note in the instructions that:
The 2 construction lines must have the "same starting point" for the new snap to kick in......
5755.7 In reply to 5755.5
Hi niko,
I just tested it with the latest v3 osx beta and over here it's working ok for me...
Like Burr mentions make sure you have placed the start point of both construction lines snapped on to the very same point.
You also need to have "Straight snap" enabled (turn it on next to Grid snap in the bottom toolbar) in order for it to kick in.
5755.8 In reply to 5755.7
Ok got it
In was doing it backwards. The construction lines would intersect but I had not started them at the point of intersection.
